Would say it's accessory and no OEM.
I think you can proof this if you look at the wiring.
Kampfkuchen hat geschrieben:Would say it's accessory and no OEM.
JokeCro hat geschrieben:Does anyone know what the name of this third brake light is? There is no way I can find such a model. I should buy such a new third brake light.
Something I was able to read from it:
Safety Mate
S3 EII 02 1368
Just TOP
Js-5609
One more thing, can that model be repaired? Replace light bulbs? Anything?
Kampfkuchen hat geschrieben:Is it necessary to have one in croatia? Maybe you can remove it.
If you want to repair it, I can try to give you some tipps if you take pictures of the removed break light. I guess the hardest part would be to open the housing.
commander_keen hat geschrieben:Never saw that solution before. If that description includes a company name, it's long gone...
How is it mounted? Glued or screwed?
If you are able to open it without damage, I'm quite optimistic you can fix it with advice from Kampfkuchen.
Kampfkuchen hat geschrieben:It depends on the method they used to close the housing. If it's glued it can be a bit tricky but not impossible. Most of the times it is possible to open it with heat. If it's screwed, it should be very easy, maybe you need a soldering iron.
JokeCro hat geschrieben:From the outside it looks like it is not glued but screwed
Kampfkuchen hat geschrieben:JokeCro hat geschrieben:From the outside it looks like it is not glued but screwed
So then I guess it should be easy to fix. Anyway it is possible that it is screwed and glued.
But.. are we talking about the housing or how it is fastened on the car?
Kampfkuchen hat geschrieben:Sounds good.
Try to open it and if you have trouble fixing it feel free to ask what to do, I will try to do my best helping you.
Lima hat geschrieben:Welcome and have a nice time here from me too - nice car, good condition... and very nice photos!
i think the brake light is aftermarket, too.
Mitglieder in diesem Forum: 0 Mitglieder und 70 Gäste
