Beitragvon Mazda RX-7 SA » Mo 14. Apr 2025, 12:14
JokeCro hat geschrieben:Team, do you have experience with Rotinger brake discs :?:
https://rotinger.com/products/brake-discs-tuning/
Personally not.
But from Mazda 6 MPS scene I know, that they work well on a 6 MPS!
Beitragvon JokeCro » Mi 16. Apr 2025, 20:02
Personally not.
It's time to change the brake discs and pads, so I'm thinking about Rotinger
Beitragvon JokeCro » Mi 4. Jun 2025, 17:12
First picture of a standard bulb, bottom picture is new Osram LED SL W5W 12V
Beitragvon commander_keen » Mi 4. Jun 2025, 23:36
Nice. Did you compare them at night also?
Beitragvon JokeCro » Do 5. Jun 2025, 15:21
commander_keen hat geschrieben:Nice. Did you compare them at night also?
I don't have a direct comparison at night, but the difference is very big. Osram LED SL gives superior light compared to standard bulbs.
Beitragvon JokeCro » Di 10. Jun 2025, 16:14
Does anyone know where I could get a connector like this for the rear wiper?
Beitragvon commander_keen » Di 10. Jun 2025, 21:28
I'm using adapter Bosch 3 392 390 298 with Bosch H550 wiper (https://www.autoscheibenwischer24.com/p ... scher-h550)
Sometimes it's offered as a bundle with the Bosch rear wiper H550 like here: https://www.scheibenwischer.com/bosch-s ... 02094.html
But you can also get the adapter separately from various sources:
https://www.ebay.de/itm/326615133840
https://www.autodoc.de/bosch/24875130
https://www.motointegrator.de/artikel/8 ... 92-390-298
https://www.lkw-teile24.de/wischergestaenge-3392390298
Beitragvon Mazda RX-7 SA » Mi 11. Jun 2025, 12:22
I've doubts it will work because of space!
That's why I cutted OEM End and welded the "U" end from another wiperarm to have the same connection like on the front.
Beitragvon JokeCro » Mi 11. Jun 2025, 15:24
commander_keen hat geschrieben:I'm using adapter Bosch 3 392 390 298 with Bosch H550 wiper (https://www.autoscheibenwischer24.com/p ... scher-h550)
Does this fit? :?:
Beitragvon commander_keen » Mi 11. Jun 2025, 21:10
Yes, it fits just well. I installed it like 15 or 20 years ago.
Since then I'm using the H550 wiper blades, which also fit.
Beitragvon JokeCro » Mo 16. Jun 2025, 13:50
commander_keen hat geschrieben:Yes, it fits just well. I installed it like 15 or 20 years ago.
This seems like a good solution to me.
Beitragvon jwbehrendt » Sa 28. Jun 2025, 22:10
Well, I did'nt weld it, I cutted the Arm & used the U-piece from a Spare and 2 screws. So can I screw it off, change the Wiperblade & screw it on again.
