Beitragvon JokeCro » Do 9. Apr 2026, 20:51
Guys, what speakers do you use in your GE? Radio? Any suggestions welcome!
Beitragvon commander_keen » Fr 10. Apr 2026, 00:56
I used to have Alpine CDE-174BT but as I don't use CDs anymore,
I switched to Alpine UTE-93DAB later.
Speakers were some Axton 5x7", but as I didn't protect them from rain water like the original speakers are covered, they died from rust (blocked membrane inside).
Currently running JBL BL Stage3 8627 6x8". (there is also Club 8622F in the same size)
The treble with these is enormous.
With 93 dB/W/m they are very efficient. But be aware that they have less than 4 Ohm. The radio needs to be able to handle that.
If treble is not your main issue, I would suggest considering to keep the original speakers and think about damping inside the door instead or as the first step even.
Otherwise depending on your radio/headunit a middle-class Kenwood 5x7" or 6x8" might already be enough.
PS: One quarter of my trunk is just wasted for an old subwoofer. xD
Links:
https://support.jbl.com/on/demandware.s ... ine_DE.pdf
https://support.jbl.com/on/demandware.s ... ual_DE.pdf
Beitragvon Kampfkuchen » Fr 10. Apr 2026, 14:54
At the front I'm using the original ones. For the back, I changed them to the same as the front ones. They are quite good - compared to accessory speakers, I really was not satisfied with anything ≤100€/pair. I checked the original ones and the bandwidth is really good. The only thing I would complain about is the position of the tweeter (as it is the same as the mid-range).
I added an Audi trunk subwoofer and I'm really, really satisfied with the sound. In my Twingo I'm using an OPTION Drive12RA (it is small enough to fit into a 14" spare wheel see here - 100% purchase recommendation by the way).
The problem with the original rear speakers is the foam surrounds - when they age, they tear a lot. But the front speakers don't have foam, they have rubber surrounds. They age too, but it is almost not measurable in 30–40 years. So you are good to go with them.
I think the biggest problem in the original setup is the radio/amplifier - you need a usable equalizer, as the original speakers are dominant in the mid-range (what can sound bad). A bit more to the high range (>8 kHz) and less in the mid-range (800–2000 Hz) on the equalizer and it brings big difference.
It is a myth that audio stuff ages badly - most of the equipment doesn't age at all, at least you can not hear this. And there is no new technique, almost everything is marketing. There are a few really big improvements, but everything is inside the preamp / amplifier (e.g. digital equalizers/filters, Class D high-efficiency amps). But speakers are the same as they were 50 years ago, with no real improvements. And if you have paper or rubber surrounds… everything is fine.
And one more tip: a bit less bass to the front/rear speakers and more to a subwoofer will also improve the sound quality of these speakers (no matter if original or aftermarket), as they have to reproduce mid sounds and bass from the same membrane, which can sound distorted. The less bass you send to these speakers, the clearer the sound will be.
And to be honest, I'm really not easy to satisfy, when it comes to HiFi. Even, if I lower my expectations in Car-HiFi a lot - because it is a catastrophic surrounding and extremely hard to clean up the sound. Just to say, my expactation isn't "at least I recognize the song".
Beitragvon JokeCro » Sa 11. Apr 2026, 19:36
Thank you very much for the information. I haven't touched the speakers and radio yet, but I think it's time to do so.
Also, I'm not familiar with the dimensions of the speakers in the front doors and in the rear on the shock absorbers (trunk)?
Beitragvon Kampfkuchen » Mo 13. Apr 2026, 23:58
commander_keen mentioned the dimensions. They are oval.
If you haven't touched the radio yet, do this first. It is quite easy and try it out if this is enough for you. The original radio is just for receiving radio waves I guess :D
Beitragvon JokeCro » Sa 18. Apr 2026, 19:52
Do you perhaps have any photos of your sound systems at GE? :D
Beitragvon Kampfkuchen » Sa 18. Apr 2026, 22:55
The only thing is the Audi 8V0035382D and the radio, everything else is original.
I cannot recommend my radio, it is an Android Radio with a big lack of memory (I think it was something like 2GB RAM), it is slow as fuck.
In my Twingo I bought a Essgoo 6,8" 1 DIN Android Radio with Octa-Core and 8GB Ram, it is usable, but it could be better in terms of sound management (f.e. you cannot setup an HPF for the speakers and no LPF for the sub) - the volume of the subwoofer output and the speakers are not well coordinated. If you turn down the volume, the bass stays loud as the mids and highs goes down. But for 100€ it's okay...
Soundsystem of the Twingo is here: https://mazda626ge.de/viewtopic.php?f=21&t=6802#p89795
If you want a subwoofer, I really recommend the Option Drive12RA.
