Beitragvon JokeCro » Di 19. Mai 2026, 18:22
Guys, question, it happens that the engine cooling fans turn on late. So, the temperature needle moves quite far from the middle, and then the fans turn on and the needle slowly returns to the middle.
This was not the case before!
Before, the needle was stationary in the middle, and if it moved a little forward, the fans would turn on.
Is it possible that it is the radiator fan thermal switch sensor?
I tried to check if both fans were working. I started the car (cold engine) and turned on the air conditioning and both fans started.
Beitragvon Kampfkuchen » Di 19. Mai 2026, 21:20
In my opinion the ECU switches the radiator fan on, dependent on the ECU thermal sensor. I'm not 100% sure anymore, but I think there are 2 thermistors and one switch for whatever. One thermistor for ECU (gasoline correction factor and fans), one for the needle.
I think what happend here is, that the NTC for the ECU has driftet a bit or the analog input has some issue. I would try to change the NTC or at least measure the resistance at cold and hot motor.
Beitragvon JokeCro » Mi 20. Mai 2026, 08:47
I also noticed a slight leak of coolant under this cap.
Does that cap hold the pressure at 1.1? Since the expansion tank on the radiator says 0.9?
Beitragvon JokeCro » Mi 20. Mai 2026, 08:52
Kampfkuchen hat geschrieben:In my opinion the ECU switches the radiator fan on, dependent on the ECU thermal sensor. I'm not 100% sure anymore, but I think there are 2 thermistors and one switch for whatever. One thermistor for ECU (gasoline correction factor and fans), one for the needle.
I think you should buy this new green sensor.
Beitragvon JokeCro » Mi 20. Mai 2026, 12:15
A little update, I had come from the city and left the car alone to run for a while. When the temperature gauge started to climb above half to a certain level when the fans turned on, not both were working, but only one.
Beitragvon commander_keen » Mi 20. Mai 2026, 17:26
The second fan is for the air conditioning condenser.
The motor cooling fan in the V6 has two fan speeds (low-speed and high-speed),
while the 4-cylinder cooling fan has only one speed.
Beitragvon JokeCro » Mi 20. Mai 2026, 19:00
commander_keen hat geschrieben:The second fan is for the air conditioning condenser.
Now when the radiator fan turns on (when the temperature gauge goes further well past halfway), there's a really loud noise, as if the fan is running at 100% speed.
This is where the fan turns on.
And then he returns to the boat.
The fan doesn't always turn on when the needle reaches the same level, sometimes a little earlier, sometimes like in the picture
Beitragvon JokeCro » Mi 20. Mai 2026, 19:36
Relay no. 1 :?:
Beitragvon Kampfkuchen » Mi 20. Mai 2026, 22:25
Okay I think I checked what's wrong:
Your low-speed is not working and when the ECU turns on the high-speed, you have a higher temperature as normal.
I also think that both fans should ran at low speed, when the temperature reaches the threshold. But not 100% sure.
You can try to go into diagnostic mode by bridging TEN to GND and then open the throttle (without engine running). The fan has to start if you open the throttle.
But I think you have a problem with your relay no 1, if it has a crack, maybe it's corrosion. You can open it and have a look. Or open it, plug it in and turn on manually. If the fan starts, this should be your problem.
Beitragvon JokeCro » Do 21. Mai 2026, 07:02
Kampfkuchen hat geschrieben:Okay I think I checked what's wrong:
Just in case, I ordered a filler cap, relay, and coolant sensor (green) because I noticed a slight leak under the filler cap.
Beitragvon JokeCro » Do 21. Mai 2026, 16:30
Can anyone tell me how to properly bleed the engine on a 2.5 V6?
Beitragvon Kampfkuchen » Fr 22. Mai 2026, 17:51
Ah I forgot the question about the Filler-Cap.
There are two caps, one normal cap and one with a spring for overpressure. If you stand in front of your car, the left is the normal filler cap. The right one, on the cooler unit, MUST have a spring. There is a hose to a coolant container, in the left fender (there is also a filler cap). If the pressure is too high, it pushes coolant into this container and in case of underpressure it sucks it from there (most likely a pressure equalization tank, but for a closed system).
If you want to bleed the engine, there are mystic ways and everybody has their own workflow, I think :D
I fill the container with 1l of coolant, then the one on the cooler to the edge. Close it, fill the left one and squeeze the hose while filling. After this I run the engine and fill again (cold engine, while running). If the level doesn't go down, I close it and drive. After some time I refill.
Worst case is air in the throttle body, because the idle valve cannot work properly. You will realize this, if your idle speed is inconsistent. If it is like it has to be, it's most likely a success.
Beitragvon JokeCro » Sa 23. Mai 2026, 15:08
New Filler cap 1.1 bar with spring
They say the filler cap should be 1.1 bar and 0.9 bar on the expansion tank on the radiator, for normal coolant circulation.
Beitragvon Kampfkuchen » Sa 23. Mai 2026, 16:33
I don't think this makes any sense.
You have a 0.9 filler cap and a 1.1 filler cap. First: original is only the 0.9, the second doesn't has a spring. Second: how would you get to 1.1? At 0.9 the expansion-tank valve opens and there is no room for 1.1bar so this filler cap never opens. Only if the 0.9 has a malfuncion, but I think this is a bit paranoid. I mean, it is not bad to have a emergency-valve, but I think this never opens.
Beitragvon JokeCro » Sa 23. Mai 2026, 18:19
Kampfkuchen hat geschrieben:I don't think this makes any sense.
Yes, exactly!
