Suche: 626 GE v6 Engine harness (93)
BeitragVerfasst: Mi 29. Okt 2014, 01:14
von FIS-X
Hi.
Sorry for posting in English, but since I do not speak or write German verry well I will write in english.
I am looking for an engine harness (the one from the engine to the ECU) for a Mazda 626 GE v6 with a manual transmission. This has to be from either a 93 or a 94 (92 if so) but a 93 is prefered.
I live in Norway and will need it to be shipped here.
Let me know if you have one for sale, I do not need the ECU.
Regards,
FIS
Re: Suche: 626 GE v6 Engine harness (93)
BeitragVerfasst: Mi 29. Okt 2014, 09:06
von Zatscha626
Maybe Kampfkuchen can help you with the harness, je has a `93 V6 but I dont know about the ECU, maybe he can tell you more.
But I think he has almost already fitted most of the wireing.
Don`t you think , the `96 harness would fit in the `93, the structure is almost the same i think...
BeitragVerfasst: Mi 29. Okt 2014, 13:05
von FIS-X
Won't he need it for his own car?
And no, a 96 engine harness will NOT fit a 93, the 93/94 models in EU are almost identical, except the 93 has an extra coolant temp sensor. In 95 they changed to the "Pre-OBD2" system in EU and US, including a new distributor. In late 95 they added the immobilizer system which is coded into the ECU and a pain to remove, these are also on the 96 and 97 models in the EU, in US they changed to OBD2 in 96.
So, a 95/96/97 harness from the EU might be interchangeable, but it won't work on a 93 or 94 model.
I even tried a 96 engine harness from the US with no luck "/
BeitragVerfasst: Mi 29. Okt 2014, 14:02
von Zatscha626
Thats bad, yeah He needs IT for his own, but if IT was working with the 96th i had give him mine because He was thinking about changing his non-airbag car to Airbag.
BeitragVerfasst: Mi 29. Okt 2014, 16:07
von FIS-X
In order to get airbag he will need to change the harness behind the dashboard, the ones going from the engine bay into the car on the left side, and the wiring harness. The best option for him would be to trace a 95 without immobilizer to do so.
Or he could buy a complete harness from the US, they had airbag from 93, but minor things needs to be fixed in order for it to work 100%.
BeitragVerfasst: So 4. Jan 2015, 03:08
von FIS-X
Is there no one who has a parts car of the specifc year that could help me out? :O
BeitragVerfasst: So 4. Jan 2015, 09:17
von Zatscha626
I dont think so. :(
But if i get one i tell you.
BeitragVerfasst: So 4. Jan 2015, 12:07
Do you habe a picture of the part you need?
BeitragVerfasst: So 4. Jan 2015, 19:44
von FIS-X
Kabelbaum, the one the ECU connects to, I can get a few pictures if needed but I think it is pretty well explaine, any junkyards that might have it?
