Beitragvon Mazda RX-7 SA » Mo 14. Apr 2025, 12:14
JokeCro hat geschrieben:Team, do you have experience with Rotinger brake discs :?:
https://rotinger.com/products/brake-discs-tuning/
Personally not.
But from Mazda 6 MPS scene I know, that they work well on a 6 MPS!
Beitragvon JokeCro » Mi 16. Apr 2025, 20:02
Personally not.
It's time to change the brake discs and pads, so I'm thinking about Rotinger
Beitragvon JokeCro » Mi 4. Jun 2025, 17:12
First picture of a standard bulb, bottom picture is new Osram LED SL W5W 12V
Beitragvon commander_keen » Mi 4. Jun 2025, 23:36
Nice. Did you compare them at night also?
Beitragvon JokeCro » Do 5. Jun 2025, 15:21
commander_keen hat geschrieben:Nice. Did you compare them at night also?
I don't have a direct comparison at night, but the difference is very big. Osram LED SL gives superior light compared to standard bulbs.
Beitragvon JokeCro » Di 10. Jun 2025, 16:14
Does anyone know where I could get a connector like this for the rear wiper?
Beitragvon commander_keen » Di 10. Jun 2025, 21:28
I'm using adapter Bosch 3 392 390 298 with Bosch H550 wiper (https://www.autoscheibenwischer24.com/p ... scher-h550)
Sometimes it's offered as a bundle with the Bosch rear wiper H550 like here: https://www.scheibenwischer.com/bosch-s ... 02094.html
But you can also get the adapter separately from various sources:
https://www.ebay.de/itm/326615133840
https://www.autodoc.de/bosch/24875130
https://www.motointegrator.de/artikel/8 ... 92-390-298
https://www.lkw-teile24.de/wischergestaenge-3392390298
Beitragvon Mazda RX-7 SA » Mi 11. Jun 2025, 12:22
I've doubts it will work because of space!
That's why I cutted OEM End and welded the "U" end from another wiperarm to have the same connection like on the front.
Beitragvon JokeCro » Mi 11. Jun 2025, 15:24
commander_keen hat geschrieben:I'm using adapter Bosch 3 392 390 298 with Bosch H550 wiper (https://www.autoscheibenwischer24.com/p ... scher-h550)
Does this fit? :?:
Beitragvon commander_keen » Mi 11. Jun 2025, 21:10
Yes, it fits just well. I installed it like 15 or 20 years ago.
Since then I'm using the H550 wiper blades, which also fit.
Beitragvon JokeCro » Mo 16. Jun 2025, 13:50
commander_keen hat geschrieben:Yes, it fits just well. I installed it like 15 or 20 years ago.
This seems like a good solution to me.
Beitragvon jwbehrendt » Sa 28. Jun 2025, 22:10
Well, I did'nt weld it, I cutted the Arm & used the U-piece from a Spare and 2 screws. So can I screw it off, change the Wiperblade & screw it on again.
Beitragvon JokeCro » Do 11. Dez 2025, 12:41
Hi Team! Since there is a lot of fog in the winter, and I drive a lot outside the city. I was looking for fog lights, Osram H3 Super or Osram H3 All Season Super (currently I have not found them on the Croatian market). Has anyone used or is using All Season Super? They have a yellow coating. Also my fog lights are yellow (not bulbs).
https://share.google/r4Vp1eoelWeK0ngwq
https://share.google/RMGHOmZCXQwDiITm1
Beitragvon commander_keen » Do 11. Dez 2025, 15:02
As you correctly stated, the yellow coating on the bulb is not necessary, as its integrated into the fog light of the GE.
(any additional coating on the bulb would result in less light or - if they would increase the brightness to compensate that - the bulb would last significantly shorter)
If you are not satisfied with your fog-lights, I would highly reccommend to check the proper alignment. My fog lights were not properly adjusted when I checked some years ago. You can find pictures here: viewtopic.php?f=5&t=4608
While it's normal that they do not keep up with the low-beam headlight without fog, the yellow light should pass through fog better than the white light in thick fog.
Beitragvon JokeCro » Do 11. Dez 2025, 17:32
commander_keen hat geschrieben:As you correctly stated, the yellow coating on the bulb is not necessary, as its integrated into the fog light of the GE.
Yeah, I thought maybe the yellow coated bulbs would be too much for the factory yellow fog lights. The fog lights are aligned well. I'm thinking about getting the Osram H3 Super, for a little more brightness. Or Osram H3 Laser? What do you think?
