JokeCro hat geschrieben:Team, do you have experience with Rotinger brake discs
https://rotinger.com/products/brake-discs-tuning/
Personally not.
But from Mazda 6 MPS scene I know, that they work well on a 6 MPS!
Mazda RX-7 SA hat geschrieben:JokeCro hat geschrieben:Team, do you have experience with Rotinger brake discs
Personally not.
commander_keen hat geschrieben:Nice. Did you compare them at night also?
commander_keen hat geschrieben:But you can also get the adapter separately from various sources:
https://www.ebay.de/itm/326615133840
https://www.autodoc.de/bosch/24875130
https://www.motointegrator.de/artikel/8 ... 92-390-298
https://www.lkw-teile24.de/wischergestaenge-3392390298
commander_keen hat geschrieben:I'm using adapter Bosch 3 392 390 298 with Bosch H550 wiper (https://www.autoscheibenwischer24.com/p ... scher-h550)
Sometimes it's offered as a bundle with the Bosch rear wiper H550 like here: https://www.scheibenwischer.com/bosch-s ... 02094.html
Mazda RX-7 SA hat geschrieben:commander_keen hat geschrieben:But you can also get the adapter separately from various sources:
I've doubts it will work because of space!
That's why I cutted OEM End and welded the "U" end from another wiperarm to have the same connection like on the front.
commander_keen hat geschrieben:As you correctly stated, the yellow coating on the bulb is not necessary, as its integrated into the fog light of the GE.
(any additional coating on the bulb would result in less light or - if they would increase the brightness to compensate that - the bulb would last significantly shorter)
If you are not satisfied with your fog-lights, I would highly reccommend to check the proper alignment. My fog lights were not properly adjusted when I checked some years ago. You can find pictures here: viewtopic.php?f=5&t=4608
While it's normal that they do not keep up with the low-beam headlight without fog, the yellow light should pass through fog better than the white light in thick fog.
