Beitragvon Kampfkuchen » Do 11. Dez 2025, 17:46
If you don't like the yellow lights (I like them alot) you can remove it. I think zatscha removed it back then, as I remember it was removable from the back. Like a dome pressed into the lamp housing. But don't throw them away!
Beitragvon JokeCro » Do 11. Dez 2025, 17:49
Kampfkuchen hat geschrieben:If you don't like the yellow lights (I like them alot) you can remove it. I think zatscha removed it back then, as I remember it was removable from the back. Like a dome pressed into the lamp housing. But don't throw them away!
I like them! :) I just wish there was a little more light.
Beitragvon commander_keen » Do 11. Dez 2025, 20:06
JokeCro hat geschrieben:Yeah, I thought maybe the yellow coated bulbs would be too much for the factory yellow fog lights. The fog lights are aligned well. I'm thinking about getting the Osram H3 Super, for a little more brightness. Or Osram H3 Laser? What do you think?
If I see it correctly, the H3 Laser is a completely different NightBreaker Model with whiter light and a blue tinted cap. (with less Lumen) That makes no sense for fog lights. They are yellow on purpose, because white light (to be more precise: the blue part of the spectrum) gets reflected more by the fog than the red/yellow parts of the spectrum.
You want reflections of the fog minimized and as much light through the fog as possible. A bulb which is more white/blue doesn't help there.
Additionally fog lights should be as low on a car as possible. (to maximize the angle between drivers exes and the lights, so reflections get minimized also due to the angle) But that's solved well in the GE.
Beitragvon JokeCro » Do 11. Dez 2025, 21:38
Yes, I understand. That's why I think maybe the best option would be Osram H3 Super?
It's not a very bright bulb, but it still gives more than a regular one.
Beitragvon commander_keen » Fr 12. Dez 2025, 00:17
Yeah, I would try with that one.
Beitragvon S1PikesPeak » Fr 12. Dez 2025, 14:23
There is another Option:
Both manufacturers osram/Philips do have Oldtimer LED Bulbs, warm white 3300k so it’s in Color Temperature like Halogen but way more lumens (about 1850lms in H1/H3). Just gooogle Osram Youngtimer LED, Phillips Youngtimer LED.
Beitragvon JokeCro » So 14. Dez 2025, 13:37
I think you meant Osram Vintage?
Beitragvon S1PikesPeak » So 14. Dez 2025, 17:37
S1PikesPeak hat geschrieben:There is another Option:
Yes, Philipps do have something Similar.
Beitragvon JokeCro » So 14. Dez 2025, 18:31
I couldn't find Osram Vintage in H3 version
Beitragvon S1PikesPeak » So 14. Dez 2025, 20:30
Didn’t think that through that the fogs are in H3, maybe there’s a possibility with an adapter but that’s maybe an huge amount of effort, not sure if its worth the effort instead of just putting in standard halogen bulbs.
Beitragvon JokeCro » Mo 15. Dez 2025, 16:03
S1PikesPeak hat geschrieben:Didn’t think that through that the fogs are in H3, maybe there’s a possibility with an adapter but that’s maybe an huge amount of effort, not sure if its worth the effort instead of just putting in standard halogen bulbs.
I think that might not be worth it
Beitragvon S1PikesPeak » Mo 15. Dez 2025, 21:09
No definitely not.
Beitragvon JokeCro » Sa 28. Mär 2026, 22:53
Small update, I changed the reverse lights. Comparison of halogen and LED Mtech
Beitragvon commander_keen » So 29. Mär 2026, 18:21
Hmmm, even your Halogen feels much brighter than mine... :-o
Beitragvon JokeCro » So 29. Mär 2026, 21:50
commander_keen hat geschrieben:Hmmm, even your Halogen feels much brighter than mine... :-o
You should change to LED
Mitglieder in diesem Forum: Majestic-12 [Bot] und 8 Gäste
