Beitragvon Kampfkuchen » Di 22. Mär 2022, 20:20
Would say it's accessory and no OEM.
I think you can proof this if you look at the wiring.
Beitragvon JokeCro » Di 22. Mär 2022, 20:27
Kampfkuchen hat geschrieben:Would say it's accessory and no OEM.
I didn't check the wiring, I never took that light off the car. But it will be time to change because the right turn signal does not work and some brake light diodes. It would be fine if this could be fixed if a new one cannot be found
Beitragvon Kampfkuchen » Di 22. Mär 2022, 20:59
Is it necessary to have one in croatia? Maybe you can remove it.
If you want to repair it, I can try to give you some tipps if you take pictures of the removed break light. I guess the hardest part would be to open the housing.
Beitragvon commander_keen » Mi 23. Mär 2022, 19:43
JokeCro hat geschrieben:Does anyone know what the name of this third brake light is? There is no way I can find such a model. I should buy such a new third brake light.
Something I was able to read from it:
Safety Mate
S3 EII 02 1368
Just TOP
Js-5609
One more thing, can that model be repaired? Replace light bulbs? Anything?
Never saw that solution before. If that description includes a company name, it's long gone...
How is it mounted? Glued or screwed?
If you are able to open it without damage, I'm quite optimistic you can fix it with advice from Kampfkuchen.
Beitragvon JokeCro » Mi 23. Mär 2022, 22:31
Kampfkuchen hat geschrieben:Is it necessary to have one in croatia? Maybe you can remove it.
I don't think it's necessary to have it, but as I believe you know, I would love to have such a third brake light. I kind of like it.
I glanced, that light has underneath, some 6 screws very small.
Possibly it can be opened?
Beitragvon JokeCro » Mi 23. Mär 2022, 22:33
commander_keen hat geschrieben:Never saw that solution before. If that description includes a company name, it's long gone...
Screw
Beitragvon Kampfkuchen » Mi 23. Mär 2022, 23:27
It depends on the method they used to close the housing. If it's glued it can be a bit tricky but not impossible. Most of the times it is possible to open it with heat. If it's screwed, it should be very easy, maybe you need a soldering iron.
Beitragvon JokeCro » So 27. Mär 2022, 14:57
Kampfkuchen hat geschrieben:It depends on the method they used to close the housing. If it's glued it can be a bit tricky but not impossible. Most of the times it is possible to open it with heat. If it's screwed, it should be very easy, maybe you need a soldering iron.
I apologize for answering only now
From the outside it looks like it is not glued but screwed
Beitragvon Kampfkuchen » So 27. Mär 2022, 16:58
JokeCro hat geschrieben:From the outside it looks like it is not glued but screwed
So then I guess it should be easy to fix. Anyway it is possible that it is screwed and glued.
But.. are we talking about the housing or how it is fastened on the car?
Beitragvon JokeCro » Mo 28. Mär 2022, 16:55
We're talking about the case.
Today I checked it has a total of eight screws
Beitragvon Kampfkuchen » Mo 28. Mär 2022, 17:46
Sounds good.
Try to open it and if you have trouble fixing it feel free to ask what to do, I will try to do my best helping you.
Beitragvon JokeCro » Di 29. Mär 2022, 21:30
Kampfkuchen hat geschrieben:Sounds good.
Thank you!
When I catch the time I will try to open the housing of the third brake light
Beitragvon Lima » Mi 30. Mär 2022, 12:01
Welcome and have a nice time here from me too - nice car, good condition... and very nice photos!
i think the brake light is aftermarket, too.
Beitragvon JokeCro » Mi 30. Mär 2022, 20:37
Lima hat geschrieben:Welcome and have a nice time here from me too - nice car, good condition... and very nice photos!
Thank you very much! I'm glad you like the photos ;)
When I catch the time I will try to open the brake light housing
Beitragvon JokeCro » Mi 27. Sep 2023, 10:54
Hello,
does anyone have this container ? Mazda 626 2.5 V6 1993 GE
THANKS!
